1 - 4 of 4 Posts
i did a search and nothing came up. whats the stock thickness of a mk3 head gasket? and how much does the engine compression change by adding a thicker or thinner head gasket. let say like adding a 2.0 mm headgasket or a 1.2mm headgasket without the head being shaved.
Is this thing on?
stock is 1.2mm i couldnt tell ya about the change tho, just take the stroke in mm and the stock compression ratio and add the extra amount to the stoke and figure it out....... i dunno i think something like that may work, or i could be talking out my ass.. i will try to figure it out later
so what is the stock stroke im mm? i just read somewhere the stock head gasket thickness is 1.2 mm..is that correct?
1 - 4 of 4 Posts
