1 - 3 of 3 Posts
1988 Supra, NA, Auto, 116K Miles
Bought some 7X6 halo led headlights off of ebay and the frame that holds the lights in place somehow doesn't fit.
Anyone experience this before with after market lights? It's close enough that I may be able to source a longer screw, but not sure if that's a great idea. I suppose it's possible not all 7X6 lights are the same shape, but I haven't been able to find any confirmed fits.
Automotive lighting Hood Amber Fluid Liquid
Wood Automotive tire Luggage and bags Bumper Fender
Discussion Starter · #2 · (Edited)
While it's not ideal, I was able to find longer screws in the same size. Hopefully this doesn't throw off the allignment too much, but I'll have to have it professionally done to find that out. Seems just fine for now!
Automotive lighting Grille Vehicle Hood Motor vehicle
Automotive lighting Font Automotive design Automotive exterior Gas
EDIT: lights were still throwing too high so I lowered them. NOW my previous electrical issue is back and they are at HALF brightness. I noticed on the way back home my brights flashed really fast once when I put the right blinker on, but I couldn't repeat it. Brights work at full brightness.
Already had this issue looked at once this year, they said I needed a new light control stalk for the steering wheel, but I don't think that's the whole story...
Stock 1989 Supra Turbo w/ Sport Roof
You could pull the headlight fuse and measure to ground and ensure you get battery voltage. In fact, measure ground at the headlight harness and make sure you have a good ground/low resistance to the body. Fuse back in, try to probe with the blinker on and off. You could use a paper clip situated in with the fuse. Be careful not to bend any tabs too much. You could also have a helper adjust the headlights while you probe it and see if you get a fluctuating voltage. That's all I have, hopefully someone will have some more insight :)
  • Like
Reactions: Rushnerd
1 - 3 of 3 Posts
