When I try too take my headlights out, everything is good except the two last bulbs ( all the way too the right on the right side, and all the way too the left on the left side.. if you are standing in front of car.) The in one seems like you have to unscrew 3 screws i guess, and on the other one the black cover part comes off, but the bulb just stays in. I need help pretty quickk.
Stock Twins King
Those outside bulbs are your fog lights. They have always been a bitch to get out, especially the drivers side because of the battery. You rotate the casing about 1/4 revolution and the cap comes off, but not all the way. Then the spring clip is revealed. You unclip that and bring out the fog bulb and then pull off the spade connectors from the harness.
Stu
