1 - 7 of 7 Posts
so im fustrated... i got the car back last week from replacing motor etc... etc... well today as im driving my middle light bulb on my driverside goes out... when i get to my destination i popped the hood and checked it out turned out it was the wire... a short of some kind.. well this bugged me because how can i go about fixing it??? how much should something like this cost???
Thanks guy
Very Senior Member
Thanks guy
which wire? can you just splice a new wire around the old?
well see the wire to the outlet seems to be screwed up or lose... im thinking that its pulled outta place because i have to mess around with it for awhile then it turns back on but when i start to drive again it turns off due to bumps in the road etc...
p.s. dont really want to embarass myself but what do u mean by splicing :scratch: explain...
Shoot Curt a post in the Elmhurst Toyota section and he can help you out with this. It's not expensive at all to replace the headlight harness.
iSketch Master!
if its the harness and wire thats jacked just go to walmart or something and buy a new harness. This is what I did as the bulbs that came with my car where some crazy wattage and fried the harness. So I bout some highbeam harnesses and now run highbeam bulbs in my lows. They are slightly brighter.
Oh and harness was like 15 bucks for both maybe less
Alex
sounds like a n easy fix dont worrie
thanks guys... i'll go check that out this week hopefully its and easy fix...
thanks again
Marc
1 - 7 of 7 Posts
