1 - 11 of 11 Posts
T
I need to know what i can use for heat resistant vacuum lines, i need to know because my wastegate has the connectors right next to the exhaust manifold and i think it will make typical lines burst, oil lines were suggested to me but this line will be withing milimeters of the manifold, are there any retailers for braided steel vacuum lines? the greddy kit i have was supposed to include those but they are shitheads and discontinued the braided lines which you see in this diagram here http://www.pbase.com/image/25321437
Do you know what "L" fittings are used with vacuum apps?
Thanks!
N
Theres no other way you can route it?
Well, put some heat wrap around the header and get those special fiberglass or whatever sleeves you can put over lines that go next to headers. Hmm, well i found one pic of it (its the orange sleeve going over the hose going down in the center). Not sure the exact name of it.
http://www.sp-power.com/images/photogallery/Honda_004.jpg
T
Nope, the wastegate nipple is right next to the manifold.
Thanks for the tip
T
T
Discussion Starter #9
Greddy Type s i believe...
I talked with Eric Kozeluh of twins turbo, and he pointed me to this: http://www.aeroquip.com/pages/prodinfo.html
StartLite® Hose (FBU)
Lightweight and Durability makes this the choice of Professionals
Race proven - approved by NASCAR, NHRA, IHRA and other sanctioned bodies. Improved Look... Pre-dyed black Nomex* cover with a red tracer braid, to ensure peak performance and a consistent fade-resistant appearance. Improved Performance... Increased abrasion resistance and overall hose strength by adding Kevlar* to the fire-retardant Nomex* cover. Eaton's Aerospace AQP® patented technology provides a smooth, firm, higher performing inner tube. Improved Applications... StartLite hose assemblies are up to 45% lighter in weight than conventional high performance assemblies.
Applications: Fuel, lube, coolant, air
What's that "tracer braid"? the very best thing you can do is get as much AIR space between the hose and the heat as you can. If it touches it WILL fry! I had cast turbo manifolds on a 5.0, creamic coated, that fried EVERYTHING I used on the plug wires including the special Nomex covers and Quartzite braid MSD sells. Even a little bit of space is MUCH better than no space and a wrap.
T
Discussion Starter #11
Harsh!
Ill see what i can do, i might be able to get more space if i get some L fittings... but what kind of fittings would fit on a "barbed" nipple
1 - 11 of 11 Posts
