·Okay, I got it the thermostat installed ($10, makes for the cheapest and easiest repair to date) (Also, I was going to post this as a reply in that thread, but I kept getting errors)
My temp gauge read a little below the middle after I let it idle for like 10 minutes, I didnt feel like driving it around so Im still not sure whats up.
When the temp got up and the car had been running my heat was blowing warmer, but still cold...
What position is the heater valve in when it is allowing water to pass through the heater core...mine is down. I turned on the AC and cranked the temp all the way down and it didnt change. But im thinking that might be because even if the climate control is set to 65 if its 38 outside, it still wants to warm it up...
By the way, I just installed the heater valve, so im not positive its hooked up right. I was told the vacuum could come from any source so thats what I did.
My car has no EGR or any of that other crap so Im missing a whole array of vacuum lines, so I couldnt hook it up to where it was supposed to be because I didnt seem to have that connection available.
If the heater valve is in the opposite position from what it should be, does anyone know a better place for the vacuum line to go...If the heater valve is where it should be, i guess just need to let it warm up some more.
