1 - 20 of 32 Posts
I broke my GReddy boost gauge a while back while trying to unplug the harness from the controller and never really replaced it. I was looking at a set of Defi gauges but the amount of work required to wire them up and place them seemed like too much of a hassle.
So, here enters CAMP 2. I could remove all my physical gauges and leverage the existing data my F-CON V-PRO was monitoring. The prospect was somewhat scary as there seems to be very little information on the internet about this unit. The HKS website has an overview and FAQ but it didn't answer all my questions... but I decided to take the plunge and get the system anyway since it was meant to work with the F-CON anyway. I just didn't want to drop a bunch of cash on the setup and be disappointed.
I had to buy a new head unit for the display. I decided to go with a Pioneer AVH-P4300DVD ($399 from Amazon). I didn't need any fancy features and the reviews were good for this unit. This unit has an input for a backup camera so you either wire up a relay and use the head unit's AV input for CAMP or use a switch and use the backup camera input if you'd like to look at your gauges and play music...
Installation of the CAMP system itself was pretty simple. The instruction manual is written in nearly perfect English (!!) and goes over everything you'll need to do. If you have an ODB2 car you'll be mostly plug-and-play. You'll need some special harnesses for Nissan, BMW, and possible others. For an F-CON system you'll need a CAMP2 F-CON Connection Harness (~$13. Part #48002-AK002. Looks like a telephone cable)
Sensors I had installed with my F-CON system:
4299-RA016 Press. Sensor/Intake Air Temp., Harness
4299-RA008 Pressure Sensor Super Wide Range (3 kg/cm2)
4603-RA001 Intake Air Temp. Sensor
There are a wide array of other sensors you can install if needed. The HKS website here: http://www.hksusa.com/products/?id=3496 has the list. Other options include, boost, oil temp, egt, etc. You'll need the optional external IF Interface to make those hookup to the CAMP system.
I have an oil temp sensor to monitor transmission temp but yet to install it.
I have an AEM Wideband which is somehow tied into the F-CON. ( I didn't do the install myself... ) The downside to this is that the actual gauge is required to be plugged in before an AFR reading is available... I'm still deciding what to do with this gauge. Unfortunately it is 52mm and won't fit into the enlarged hole in my dash.
So, onto the good stuff!
Display in digital mode. You can monitor and display 6 different inputs at once
This is the analog mode with additional digital data. You get one analog gauge and the rest in a digital format
So here's the full on analog gauge mode. You get 3 different inputs for gauges here and can select between white, black, and red as gauge colors:
I think the red is a bit hard to read and the white is too bright...
And of course here is the data logging mode where, again, you can monitor 6 different inputs at once
Here's a shot with it in the dash ( I need to fill those other holes up with something now! )
The system is also configurable for warnings (visual and audible) and peak hold.
I haven't been able to drive the car yet as I'm still missing a front bumper but so far I'm really happy! I'll have NO visible gauges and will have access to a treasure trove of data at the touch of a button!
Big thanks to Eugene at SP Engineering for getting all the parts together for me on such short notice. Thanks buddy!
AEM v2
Now if only AEM will come out with one for the V2 to work with my AVIC D3. I love this thanks for sharing.
· Boost Addicted.
Nice setup ..
Have you turned it on and off a few times?
I wired my power for the camp2 and the IF unit from the cigarette lighter. Earths I feel pretty confident in. When I turn the car off, the next time I start it, it hasn't stored my gauge display preferences so it resets to the default gauges. It's annoying because I want to set it up to display certain gauges and be able to always have those as my defaults when it starts again.
The AVCR does this so I expected it to be a normal thing. Let me know how you get on as there aren't that many of us running the Camp2
Discussion Starter · #12 ·
You need to hookup the yellow wire (constant) to a constant source. I'm a bit "ghetto" at the moment and used the constant off of the head unit as I couldn't find the old clock wiring and couldn't find a wire on the ECU harness. Once you hook that up you'll be good to go. When I turn it on now it has all the settings memorized and even brings me back to the same screen I had when I turned if off! So if I'm on the digital section it'll dump right back in there again on power up. pretty neat!
· Stock Twins King
I had this setup about 2 years ago ... it is a nice gimmick but too slow to be useful :(
Hope not cause mine is going in tomorrow. I just removed all my outdated Defi Link gauges for this. What do you mean by "too slow"? screen refresh? I need it mostly for Oil and Water temps and Oil and Fuel pressure.
Stu
· Mr. 2JZUL8R
Installed one in a heavily modified R34 to work with his headunit and one in my buddies IS300 Turbo on a 6" monitor where his gauge cluster used to be (relocated stock cluster to the glove box since fuel gauge and mileage was not setup on CAMP2). Great setup all in one place. The startup screen is my favorite part! "HKS" ;)
hi everybody sorry for this being a first post but ive been searching the web to find out how to finish installing my camp2 unit and if unit
ive bought my camp2 with if and sensors 2nd hand and it didnt come with the manual / wiring diagram
the problem i have is ive got 4 wires that come off the if and obviously need constant power , ign power, earth but what does the 4th do?
ive linked yellow to constant
red to ignition power
and black to earth
white i dont know what white does
when i power everything up the camp2 it doesnt think the i/f unit is connected
sorry for being a pain but hks wont help me
· Stock Twins King
and black to earth
Email me and I will send the install manual. [email protected]
Stu
Great alternative to those who do not want to run multiple gauges on the A-pilar. Has anyone run this with OBD1 cars? I know the Camp2 is OBD2 specific but the only way to run it on a OBD1 car is to run the HKS VPro engine management?
· Stock Twins King
I am a OBDII car but elected to go with the "optional" harness HKS sells that basically does all the same as If you were an OBDI car, but requires tapping into the OEM Main harness. It is all explained in the manual. I had to do this as I am a stand alone ECU.
Here is 1 pics of the screen in my car.
http://97supraturbo.com//Images-New/Gallery New/New Interior (5).jpg
Stu
1 - 20 of 32 Posts
