1 - 3 of 3 Posts
Does anyone know if there are any good cheap upgrades for an 87 N/A? I'm new to the supra game and imports all together means im only 17. I want to find so easy upgrades to make my car a little quicker, some throttle response, and just all over look... My step dads friend owns an exhaust shop so im getting custom bent pipe there... anyone know if theres intakes that work or if one off an MKIV would work N/A? Help Please. :confused:
Found E85 NOT in NJ!
I am sure you could make an intake work. I mean a basic intake is just a pipe and a filter (unless you get a cold air intake but I would then get a bypass valve so you don't suck up water).
I am assuming you have a 7MGE, I THINK there are people that are running turbo setups on it.
You might have better luck over in the MKIII section.
wait you should start small if your a noob to the "supra game" first get your cold air intake and exhaust done first then you can move on the thing like ignition and fuel also upgrading the suspension will help in your quest for power so start there first
1 - 3 of 3 Posts
