1 - 7 of 7 Posts
well i bought the wrong turbo its a t04e with a t3.t4 flange i was wondering if i can swap the housing to make it a t4. the compressor side says A/R.50 and the exhaust side where the down pipe connects to says A/R.84 now can i swap that for a T4 Turbo .68 TANG V-BAND Turbine Housing P-Trim ? any help would be good thanks
NSW supra club Member
yea, why not? if your gonna say something like that, at least back it up?
I had a to4e with a 1.32a/r p trim in the to3 flange, i swaped it for a 1.00 a/r p trim to4 flange with no problems!
As long as the housing came off the same wheel trim your gonna use it with(in this case, p trim), i dont see why it wont work.
Cheifbootknocka
Yes you can. Look here for the dims http://www.turboneticsinc.com/turbo_dimensions.htm
But more importantly, will the turbo supply the amount of CFM you need ?
1 - 7 of 7 Posts
