Guys last night after driving for about 10 minutes the warning light (!) only came on in the tachometer. There was no other light that came on with that.
Currently I do need to install my O2 sim for the check engine light (O2 sensor) but this was not the same because I can reset that by reseting my ECU. I tried to reset my ECU but had no luck the light would not go off!! Eventually I got sick of it and went to sleep and this morning I checked it again and it was still on.
Do you guys know what and why this is coming on? I checked all my hoses, oil levels, brake fluids, coolant, power steering fluids, parking brake lever, etc. There is no loss in performance nor any strange noises.
What should I do?
What should I do?
