Hows the front main seal come out??
Okay heres the deal,
Went out in the car hit boost (17lbs, single) and it was leaking oil from the front of the engine, so i did my research on the forums and found out a couple different things it could be. started tearing into it (taking the plastic covers off the timing belt and what not... turns out it seems to be the FRONT MAIN SEAL... oil all over the timing belt itself and looks like the oil is coming from behind the crank.
ok well i cant seem to get the crank bolt off for the life of me. I've tried everything. I just want to make sure that the bolt, to loosing it needs to go to the left (passenger side)?, but this is what i've tried.... using the starter to break it loose - negative - tried like 10 times didn't want to hurt the starter ... next tried force with 3' breaker bar, and i had it in 6th gear e-brake on and someone in the driver seat applying the breaks... its turns pretty much everything the opposite way ( i turn the crank pulley 180degrees and the bolt wont break loose) next tried 2 impact guns, one not that great, the other supposed to be high rating.... my next option is to get an industrial impact gun (one that works on industrial equipment) and pray that it works.... what else could i do, will a certain part make this bolt come off???
everyone says just keep working it, well i have been for 2 days, (4hrs a day) i dont know what to do
also on a side note I dont want this to happen again so I am just wondering what people are doing to help with the blow by pressure leave the bottom end so it doesn't blow out the seal????
I plan on building the motor (113k) but not till at least winter or maybe spring so i want the car to last till then .... any info that you have to help me out will be greatly appreciated .... sorry for the long post
