1 - 3 of 3 Posts
New problem, Hopefully resolved easier than the rest!
My battery is being drained when the car sits overnite!
If I jump it it runs fine. I can park it for several hours and it cranks, but over nite I turn the key in the morning and get nothin!
Any suggestions as to what the culprit may be!
Malik
well if weren not their to do tests, it will be impossible for us to find out what it is, do a parasitic draw test it only takes an ampmeter, it shoudlent be mroe then .02 amps if it is, then obvi something is stayin on, look for aftermarket relays and replace them with toyota, and take a test light and look at your fuse box and find out what is NOT supposed to have power with KO (key off) and if it has power, attack that circuit,
Have you done any electrical modifications lately? If so, check there first.
If not, like nose gobblin said, check your fuse box and find out what's drawing current with the key off.
In the meantime, just disconnect your pos battery cable overnight. You'll have to reset any clocks or radio stations but you'll have juice to start in the morning.
1 - 3 of 3 Posts
