1 - 20 of 53 Posts
· REVTECHRACING.COM
i toasted my act heavy duty plate ans street disc after just a few months. now im asking for tips on how to choose the "right" clutch for my needs.im runnin a bl 67 kit and fuel no n2o and drive to work twice a week with the car and race on weekends. so far i have 2 type of excedy clutches to try.tmo43sbmc carbon and the tmo4335r metallic disc. car only makes mid 600 rwhp. any ideas from some of you who are in my shoes?.
az/wotm clutch
· SupraForums Sponsor
The HPF Feramic or HPF Bronze disk with ACT Heavy Duty Pressure plate and stock flywheel.
[Is there an echo in this thread?]:)
Take Care and good luck with the next clutch choice.
· REVTECHRACING.COM
Discussion Starter · #11 · (Edited)
thanks for all the replys but someone let me know why i shouldnt use my fidanza fly? i still have a stock fly in my closet and i can buy a new fritction plate for the fidanza also but why switch back? and why not use the act xtreme plate over the hd plate? i have the act heavy duty now with only 1k milesonit ,can i reuse it?
keep in mind i just put 28x11.50x16 et streets on which stress the clutch a bit much. which is why it probably burnt up so quick..
WEST said:
The EXEDY tripple almost drives like stock.
Any problems with the exedy holding power? I am hope it dosent engage like the hks triple that i have now :( .
I havent heard of anyone runnign the exedy?
· REVTECHRACING.COM
Discussion Starter · #13 ·
hpf said for me to use a stock flywheel and run a bronze unsprung disk with a at hd pp. this sound right? can i have my stock fly resurfaced and use it.?
Sounds right... yes you can resurface the flywheel. Not too many places can though. I send mine to South bend clutch for resurfacing. Good luck and that clutch should not dissapoint.
Matt
· REVTECHRACING.COM
Discussion Starter · #16 ·
hpf says the use of my fidanza fly isnt recommended for drag use. but i already have the fly and just need to by a new friction plate and use the bronze sprung disk and all should be ok.??? can i get away using the fidanza fly and a sprung bronze from hpf? any downsides to this combo??
They say not to use the fidanza as it doesnt disapate heat very well and their clutches fuse to that pretty easily. Mine bronze sprung fused to it in under 7000 miles if that. I just slipped it to hard, but i wouldnt reccomend that setup ask chris he will tell you the same thing
turbosupe said:
Has anyone run the southbend setup? Im probably going to order it for my car and was wondering if it was pretty slippable
I am in the process of installing my Southbend dxd-tz clutch kit.Before i ordered mine,i spoke to Andy their,He told me it's slippable and it's almost like stock.I asked him if my wife can drive the car with it in and he said yes.
My original stock clutch finally went out on me this past weekend. Since I had such good luck with it and I'm only at about the 500 rwhp level I was thinking of just doing the Bronze disc and South bend pressure plate. Seems like that would be closest to stock slippability and feel. Anyone have any experience with it?
I just installed a HPF Bronze disk with a south bend PP with a RPS LW FW. I only have 20 miles on it so far so this is only an initial impression. My last clutch was a ACT PP with stock disk/FW. Stock like engagement, heavy pedel pressure, didn't hold up to being slipped at the track.
So far my new combo engages almost as well as a stock disk, much lighter pedel close to stock. I also feel that the lighter pedel make it eaiser to modulate the clutch for smooth engagement. I'm sure that once broken in this clutch will be totally a non issue as for as streetability goes. I've driven 2 supras with RPS PP's and AZ disks and a RPS carbon carbon and they are all like on/off switches compared to this new combo.
If it holds well at the track I'll be very happy with it.
1 - 20 of 53 Posts
