I'm hitting what sounds exactly like rev limiter at 5k rpm. It only happens in first gear and it only happens about half of the time I boost. I know that this ISN'T boost cut because I can boost fine in all the other gears and boost cut doesn't sound like a rev limiter.....it just shut the engine off. Has anyone else had this problem before.
My current setup is.....TSO4, full bpu, with blitz bov and hks ez. This problem used to happen every now and them also with my stock twins. I suppect that it is fuel cut. Any suggestions???
thanks
www.eastcoastsupraz.com
thanks
