1 - 20 of 35 Posts
I posted the same thread in General Discussion forum but didnt get any response yet so I thought maybe its in the wrong forum?
So heres my question...Which one is better to tune BPU for more HP? :)
There are a few JDM Soarers turbo's for sale here in Korea
There is only one 96 model= vvti + single turbo
The rest are 95 and earlier= no vvti + twin turbos
heres the 96 model about 56,000 kilometers and about 18,000 USD!
http://www.bobaedream.com/cyber/Cyb...tat=&gubun=ImportCar&features=&cat=&x=17&y=11
this is a 92 model with 77,000 km
http://www.bobaedream.com/cyber/Cyb...tat=&gubun=ImportCar&features=&cat=&x=38&y=13
I plan to buy one and tune it BPU= full exhaust, intake, FMIC, ECU and up the boost considerably.
I heard that that the stock turbos need to be upgraded to steel turbines replacing the ceramic turbines to go beyond 14.5psi
Which model is going to have more power BPU max allowed psi, the twins or single? Thank you so much for your input...
I will post pics when I get the Soarer!
JDM-yo :bigthumb:
btw what is the average HP on BPU 1jz-gte?
1JZ BLING
how about non and make life easy.
Elaborate please? If theres no significant difference from BPU power levels I'm leaning towards the 96 vvti model because its newer/less mileage and I like the redesigned front bumper...I'm only going for BPU and maybe modifying the stock turbo(s) nothing crazy
I used the seach button but all I founded out is the vvti ECU is hard to tune in higher HP like 500+ Is the vvti ECU that much of a hinderance?
I'd go vvti, i am pretty sure they are actually putting more power out of the box than the non vvti. Kinda like the real power ratings on the 2jzget vvti aristo.
Used parts from japan are easier to find for the non vvti engines though.
the vvti models also run 9:1 compression compared to the 8.5:1 of the non vvti, so that may factor into your decision also.
Moderator, l337 M0d3r4t0r
Hey man,
if you are just going BPU i'd say VVTI for sure!
Can't go wrong. if you plan on going further go for the older one
May want to ask on the celicasupra forum, they have quite a few more vvti swapped cars than this forum. I asked the same question, and the few that replied said the vvti.
Discussion Starter · #15 ·
yes the more i learn about the vvti 1jz, it seems like it could make decent power with a PFC piggy back ECU and a bolt on upgraded turbo (forgot the name of it) to replace the CT26
thanks for the pros and cons!
1 - 20 of 35 Posts
