1 - 4 of 4 Posts
I have the SP 58GT (61mm) single turbo kit installed by SP
Greddy Profec B
RMM DP and HKS Ti exhaust
There is no BCC on the car but there is definitely no Boost Cut...
Right now it is at 19psi and makes 484whp, but I want more. There is absolutely NOTHING else done to it. I already plan on installing a good FMIC and a BL transmission and 3200 converter. What fuel system parts should I get to acheive closer to 600whp? I'm talking about electronics as well. I've noticed the VPC is no longer available and that's what most of you use??? What do I do :dunno:
Hardtopper Once Again!
A fuel system with 720 injectors will be more than enough for your 61mm turbo and I also would consider the Map ECU for fuel tuning.
It's possible that I may upgrade to a 67mm turbo within the next year as well, so would the 720cc's be enough for that too? Also on the fuel system, I'm planning, for the following parts. Dual 255's, lines, Aeromotive regulator and a fuel rail. Is there anything else? that almost seems too easy. What size fuel lines?
1 - 4 of 4 Posts
