L
Lightning
·Guest
help me out, loose bolt
I was driving around and suddenly the shifter started feeling rough and we heard a clicking noise from the engine bay. I pulled over and popped the hood. It was coming from the fan area and I was only about a mile away so I limped her home. She sounded ok once I got up to speed. The heat started going up a little, to about 60% on the gauge. A couple times the battery light flashed on while I was turning. Anyway at idle she was clicking like crazy and so I turned it off and checked for codes. Fast blink so none. I look a little deeper around the fan area where the noise was coming from and found this just resting at the bottom on the undercover of the engine bay. I think the clicking might have been the fan hitting this bolt. The tips of the fan are worn and scratched a little bit I don't think it was like that before. Also all the belts and pullies seem tight and not loose. Somebody please tell me, without flaming
, what is this bolt and can I just put it back in and assume everything is ok?
