1 - 7 of 7 Posts
Allright guys i need your help , i have a 88 n/a supra , it misses as it idels and as i accelerate, it has new spark plugs, new ngk wires, cap, rotor, coil , the dam thing sounds like a lawn mower , when it idels it ...it sounds like it "PUTS". i allready removed all the water and fluids form around the sparkplugs and all thet stuff, and it still has the same problem . what could this be ?
thanks jason
check the seals on the distributor itself...if not the timing issue maybe its just the good ole wet distributor issue...
also...since you had water around the plugs...i would leave it open for a while just to make sure its all dry...i got some water in that gulley before...thought i had it dry...still misfired
left it open for a week while i was at school then hit it with some compressed air (plugs were still in because i didnt want the water falling into the cylinder)...felt like new
any little bit of water in there will make you misfire
1 - 7 of 7 Posts
