1 - 4 of 4 Posts
Ok so the other day my car was running like crap on startup would rev to about 1500 then stall, and if i hit the gas it would stall... im stumped i just changed the fuel pump and the fuel filter thinking it was that but its still doing the same thing, any ideas
From the land down under
Do you have an IACV? If so, inspect and clean it, and as above, check that your TPS is set to factory spec.
Also, check for obvious problems like the vacuum lines that might have come loose etc
1 - 4 of 4 Posts
