I cut the hole in the stock clock location a little larger to accept the 60mm boost gauge.
All you need to do is find a switched 12v source (you can use the wire on your clock harness) and then connect the ground to the wire from your gauge. Just go to your local Radio Shack and get a 12v 120db siren.
Later, Steve
