1 - 4 of 4 Posts
I like napps
Well to start just got a used profecA everything is installed and cant get the dam thing out of learning mode. its stuck in "P-1", and sometimes i can get it to "P-2" . other then that im at stock boost when its all connected. and i followed the vac diagrams, heres one soruce that i used http://greddy.com/tech/PROFEC_A_B_HELP.pdf i also have the dipswitches in the On position which is down on the controller. If any of you guys are familar with this EBC LMK. thanks
Dust
I'm running the greddy profec-a. You probably already know that it's stuck in learning mode, so you just need to complete the process. If you have the instruction manual, it should tell u how to do it. I have the printed version, but i think it's also on the greddy website. If not, when in P-1 mode, u must to a full boost run in third or fourth gear. It should then automatically switch to P-2 mode, then u do another full boost run. Then it should be normal. Hopefully that works. tell me how it goes. Hope that helps.
1 - 4 of 4 Posts
