It would appear as though the coil dwell and ignition phasing is different on the new AEM 6101 boxes than it is on the v1 1100.
2JZ-GE w/TT hadgasket, NA wiring harness
67mm turbo, 3.5bar MAP, distributor
The car is hitting wall between 3500-4100rpm and when it does the rpm tach drops. The car is eating ignition coils. The distributor rotor has been phased properly and timing set on the AEM at 15 degrees. We've tried setting the 1st ignition tooth to 21.53 but there isn't enough timing resolution to sync the timing when we change the value. The car just shuts off right away.
Is anyone else having this issue? I wish I could just plug in the coil and ignition values from the v1 that's working on my car but they just aren't working for the v2. What is everyone else using for the distributor on the 6101 boxes?
