Jarrett,
1. I have your turbo kit for NA-T and have the intercooler that came with no screws or mounting hardware whatsover, can you help me out? Do you have any mounting instructions?
2. I wasn't sure but was I supposed to get a oil flange of any type with the kit to bolt up to the oil pan when I drill it? Or am I just to tap it and run the line only?
(All I received was the line only)
3. Also, I have the fuel lines/bypass line, injectors/clips, and Aeromotive FPR but wanted to know since I'm using the factory OEM fuel rail do I tap that rail to fit lines and Aeromotive FPR? Or do I need the aftermarket rail for it to all work?
*Edit* Looks like I've found evidence on your website from Elliot Ficek's NA-T car that the stock OEM fuel rail should work if tapped. Correct?
Thanks,
David
Thanks,
David
