·I have installed a JVC KD-SH99 Headunit in my 95 NA...........
I have not used any wiring that was already in the car.......
Meaning, I ran my own power, acc, ground, & speaker wiring..........
I simply unhooked the headunit & amp, and removed them leaving all factory wiring intact (as I may reinstall later)
My questions are.....
What wire should I connect the power antenna lead on my stereo to on my car? To get the antenna to go up when the radio is on.....
And also what wire should I connect the dimmer wire on my stereo to......so that it dims the headunit when the lights turn on....
Thank You for your Help!
Jason
95NA
Jason
95NA
