1 - 4 of 4 Posts
HELP, i just put the BCC on, and the car is boosting from 1100rpm to 2200rpm repeatly and automaticlly,
i took the BUP off now, i donot know what to do?????
and i put the DP and catback already before this.
-Ming
:eek: :eek: :eek:
Hmmm what wire did you hook up your BCC wires to ??? u make sure its the right one going into the ecu and away from the ecu ??? or did u even check if its the right wire... if u have the in and the out hooked up backward it would fuel cut real bad.... now which wire did you hook it up to on the ECU anyway to make it build boost down that low??? 1100-2200 rpm automatically... didnt know our cars can do that..... good luck :eek:
Okay, i got it.
because i wired the Blue-black on ECU instead of the Yellow-Black,
according to the MR2 diagram,
i am clear now.
but the car is quiet than without the BBC and with the DP?
yep, is not that? automatically can boost using that blue-black!!!
all my friend were saying "Supra are so cool!"
i can sing...."Hwool, Hwool....!" i guess someone should do something auto...boost or what, LOL!
-Ming
Glad you got it fixed... next time u get something conncted... ALWAYS DOUBLE CHECK the wires... otherwise connecting the wrong wire to the wrong thing sometimes could be a costly mistake... and I got it now yours is a auto thats why its able to do it... good luck.... double check wire and work next time :D
1 - 4 of 4 Posts
