1 - 1 of 1 Posts
i have a 90 civic 4dr auto, and today my ignition assembly decided to give out. the key will start the car but wont hold the circuit so it will shut off as soon as i let go of the key. looking at it closer and messing with it i can see that the key and cylinder is ****ked. anyhow my questions can anyone help me to hotwire this bitch for th moment till i get a new ignition cyl, assembly?
heres the codes
CIVIC 1987-1991
WIRE COLORS LOCATION
12 VOLTS CONSTANT WHITE/BLACK IGNITION HARNESS
IGNITION 1 BLACK/YELLOW IGNITION HARNESS
ACCESSORY/HEATER BLOWER 1 YELLOW IGNITION HARNESS
STARTER BLACK/WHITE IGNITION HARNESS
PARKING LIGHTS ( + ) RED/GREEN AT HEADLIGHT SWITCH
DOMELIGHT GREEN/RED WHITE CONN. AT FUSE BOX
POWER DOOR LOCK GREEN/WHITE INSIDE OF DRIVERS DOOR
POWER DOOR UNLOCK GREEN/RED INSIDE OF DRIVERS DOOR (TYPE B)
TACH SENSOR BLUE AT COIL
BRAKE GREEN/WHITE AT SWITCH ABOVE BRAKE PEDAL
HORN BLUE/RED STEERING COLUMN
1 - 1 of 1 Posts
