I have a 94 n/a auto with a turbonetic kit -- I have a ton of miles on the car but im hoping it doesnt need a rebuild on the tranny..
Transmission shifts fine through all the gears then locks the torque converter..
on light throttle pressure of just keeping a steady speed the torque converter flares and unlocks.. then after a few seconds it will lock back in.. and will keep repeating randomly..
Does anyone have any advice.. anything i can check to either eliminate or to find the cause..
Thanks Tyler
In case anyone cares to read.. Found cure.. the previous owner said what ever you do.. do not touch the throttle possition sensor because i have it adjusted just right.. well the tps was exactly what was causing my car to unlock and lock back up... out of adjustment..
The Great Kruso
