1 - 2 of 2 Posts
Hi have anyone done S1-S2 dash conversion before?
Basically mine already done S2 dash conversion on my pre facelift. Everything seem work fine.
Just only couple things is heater control and tacho aren't working .
So I assume could be clock loom might be different from S1 and S2 but the plugs straight fit in the clock cluster
Trd tacho oringnally came off NA but I modified resistor and its was worked on TT.
Tuning garage took my tacho out and wiring to syvec ECU, still not working.
Anyone have similar problem?
Stock Twins King
what did you do to change NA to TT? Did you remove the 43k and put in a 1k? That is the proper way and has worked for me every time. I am stumped tho...are you stating you fitted in S2 cluster into a S1 car? That can be quite a job as not all pinouts crossover. A NA cluster has the tach signal wire straight from the Igniter. TT it gets it off the ECM as a 5v signal. Now the 1k resistor fixes this w/o rewiring to the ECM 5v signal. I guess it depends on how or where you are getting the proper tach signal
1 - 2 of 2 Posts
