1 - 20 of 20 Posts
Yup, every gte has one. Its on the leftside of the car on the wheelwell.
Here's a pic of it's location, i was going to say drivers side well too but since he's in australia that'd set him of on the wrong foot ;)
Basically it's a Pentiometer. Almost like a MAP sensor. As Manifold pressure increases it pushes on the diaphram rasing the voltage out put and sending it to the ecu if it reaces a certain voltage then it will initiate fuel cut.
On my MR2 I can disconnect the Vacumm line to disable Fuel cut on the 7M I dont believe you are able to do it that way. I tried on my friends MKIII and it kept intiating fuel cut at 14-15psi I believe.
Mitch
cheers guys ive never seen 1 of them on my car
i dont have a factory boost gauge as such, more that turbo light turns on when makingt boost..... my spare plug is on the drivers side (left looking at my pics).. so i take it i dont need 1 then??
It could very well be possible that this boost pressure assy is just for the boostgauge in our supra's
boost freak
like a MAP sensor? it IS a MAP sensor.
Mitch
the 3S MAP trick won't work, on MA70s the MAP sensor is just there to drive the boost gauge.
possible? nope, that's a fact.
^^ the 3k pipe is a slight bit higher then the TB hence the weird shifted look
239RWHP @ 9PSI
that motor is cleaaaann.
LEADED FUEL ONLY
Mitch
To elaborate....
The mr2 and 7m electronics are totally different.
The turbo pressure sensor has nothing to do with ECU operation. It is merely a sensor for the boost guage unlike the MR2.
I wish it wasn't this way, but it is. :(
1 - 20 of 20 Posts
