·I've Installed the Greddy 52mm electric boost gauge, but it doesn't seem to register any boost or vacuum. I Hooked it up to the clock harness and I think I got all the wires spliced correctly. The guage has power when the car is running. As far as the sensor goes, I connected it between the FPR and what I think is the VSV(small little blue thing that has a vacuum hose runing to the FPR and the factory turbo pressure sensor). When the car is running there the master alarm light is dully light, but not as bright as when you have the emergency brake on. I need some help here guys. What did I do wrong???
Thanks.
Thanks.
