1 - 7 of 7 Posts
Hey guys Im trying to finish wiring up a few things to my proefi 128. Im on the wheels speed sensors now and I was wondering where you tap the wires from the sensors? What wire colors are you looking for? And what pins on the ProEFI do you attach them to?
Does it matter which rear wheel you choose? Does one have a tendency to slip more? I have the trd lsd if that would matter.
At the ABS computer would I want to tap the "L" wire from pin 2 on connector A18 for the Right Rear Wheel and splice it into J1 A01 on the ProEFI? And would I tap the "R" wire from pin 17 on connector A19 for the Right Front Wheel and splice it into J1 A12 on the ProEFI? Or do I want to tap into the WSS digital output wires at the ABS ecu?
I would also need to wire in the "trac off" indicator light into J2 B21 or J2 B02 on the ProEFI right? Along with the Traction Control Switch to pin J1 C11?
1 - 7 of 7 Posts
