I recently changed chassies and I had my AEM wideband hooked up to the old chassis and I have a baseline for my motor. I put the motor in the new car and now the AF ratios have changed, here they are:
16.3-15.8 on the cruise freeway speeds steady 1/4 throttle (way to lean)
Full throttle from freeway speed it shoots to 10 one second, then to 13 straight out no transition, one second, then back to 10.0-10.5 and then steady 10 all the way till redline(I assume, never took it there)
I know of an exhaust leak upstream the AEM UEgo but down stream the stock o2 snesor (Its the flexable part of the DP that is leaking.) and the AEM is about 4 inches down from that leak. but that leak was worse (No DP gasket) on my last chassis aswell so I dont think that is effecting it all that much. Or is it?
Any input is great I was concidering it might be a mixture misfire?
