I have just rebuilded my engine and when i fill it up with coolant it drips continuisly, well its not a drip its a constant stream, i dont know where it comes from exactly, it drips from the crankshaft pulley and it has a stream that falls on top of it i havent touched nothing above the crackshaft and dont know what possibly could be there that has coolant, i look from the top and the main coolant hose to engine does not drip, neither does the metal part with all the sensors I am totally lost any ideas?
7M POWAH! baby ;)
water pump gasket :dunno:
Just some guy
Only coolant sources I can think of that might drip around the crank is the water pump, the 90 degree hose from under the thermo housing, the thermostat cover, and maybe the upper/lower rad hose connections on the engine. Then of course, it could be coming from the HG, but lets hope that's not the case.
