1 - 14 of 14 Posts
Hello Everyone.
I have owned my DJG Supra for about 3 years now and have started to do some additional modifications. I love the look of the stock wheels and body, but would like to up the game a little.
My current modifications are:
3" Tanabe Downpipe
Patch Harness with BCC
MBC set at 17psi
Wastegate spring mod and shimmed the rear wastegate (12-13 psi 1st turbo, 17 psi second turbo)
New NGK Plugs
Southbend Stage 3 Endurance with OEM DMF
Tanabe Sustec GF210 Springs
H&R Trak+ Spacers 15mm back, 20mm front
HKS Silent Hi-Power (Special Order, Still Waiting)
Car sits great now.
259182
The main problem I have now is in gears 1-3, I immediately loose traction when the second turbo hits. It doesn't help that I have some old Toyo 300 treadwear 255/40/17s. I recently picked up two old turbo wheels that were gouged up and dull and had my wheel guy bring them back to life for $150 each.
259183
259184
So enough of the backstory. I am thinking about getting this extra set of 17x9.5s widened so I can put my current rears on the front and some widened wheels on the back, but don't know what width I should go for because tire sizes are so limited.
Essentially, I either have to go with 275/40/17 or 315/40/17. I would hate to have to hack up my rear inner fender wells, so I assume the 315's are out of the question? I also hate the way 275s seem to bulge on the OEM wheels, and 888R run wide so it would be even worse (I would think).
Should I widen them to 17x10.5 to accommodate the R888R 275/40/17? Would 11.0 look too stretched? Is widening a waste of time and I should just stick to a 275/40/17 on a factory wheel? Like to hear your thoughts on what you would do to get the best looks and traction?
Old School
I had my stockers widened to 10”, perfect fit for the 275/40-17 Michelin PS2 that I ran for years. I widened the front 8” rims, put them on the back with a 1.2” wheel adapter and moved the 9.5” rears to the front with a 265/40 PS2. The increase in front tire was huge for overall handling.
  • Like
Reactions: Strokercharged95GT
Super Moderator
A stock 17x9.5 is great for a 275/40/17. I can't speak to your subjective tastes but I personally believe R888R's and RT615's and NT05R's in that size all look fantastic on the stock wheel.
I would never run something as narrow as a 275 on an 11in wide wheel. A 17x11 or 11.5 should get the 315, without question.
But before spending the money and potentially messing around with different spacers/tire sizes etc, I'd buy a set of sticky and proper performance spec 275/40/17's and have those mounted on the new rear wheels as-is and see if it serves your needs.
Move your existing 9.5 rears up front as you planned already, but go for a nice handling 255/40 or 265/40 for those. Make sure to have the tabs removed that deliberately interfere on the front TT calipers - Toyota did that to prevent an ignorant early 90's tire shop from swapping the fronts and rears by accident.
If that setup does the trick, no need for widening the wheels or changing anything else.
  • Like
Thanks for the responses, I am now leaning towards just sticking the 275s on the new wheels. But before I order the tires, I would just like to play devils advocate on the 315/35/17s first.
I am currently running a 15mm rear spacer. I did a rough measurement with the car on the ground between the inner wheel lip and the shock/spring, and I had roughly 40mm of clearance (rough as in I just held up a tap measure and eyeballed it). This tells me that if I left the 15mm spacer in its place and widened the wheel to 11", I would have something like a few mm's of clearance on the inner portion.
So hypothetically, if I did widen the wheel to 11" and bought a smaller 315/35/17 (like a Nitto), how much of the fender lips would have to be trimmed back? Would the tire hit other things inside of the wheel well I am not thinking about? Would the 315 be so bulged on the 11" wheel that it would be worse to drive? I honestly am not totally against trimming the fenders, I just don't want to trim them back so much that the arch loses rigidity.
edit - using wheel math with a 17x9.5 +50 widened to 17x11" with a 15 mm spacer the offset would be around +54.
[50mm + (38/2)] = 69mm -15mm spacer = +54mm
Moderator
I have been running tires in the "Extreme Performance Summer Tire" category at the stock 235/45R17 front and 255/40R17 rear sizes on my stock wheels for a very long time. Honestly a stock size can work as long as the tire is good. I "daily" with these tires. They don't last forever but ultimate grip is what I want.
I had these in the stock sizes front/rear for the last 5 years...
Bridgestone Potenza RE-71R
These have been discontinued. There is an RE-71RS in Asia but that has not come over yet.
I am replacing the RE-71R's this week with these tires...
Yokohama Advan A052
Testing Extreme Performance Summer Tires 2020
From the land down under
Just as a side note, if you do end up moving your 9.5" rears to the front, and widening another set of factory rims for the rear, be sure to widen a set of 9.5" rears, so the "lip" isnt shallower on the rear than the front.
Admittedly, there is only a subtle difference in "lip", but its noticeable enough to look a little odd
Super Moderator
The 11.5 widened wheel will leave you at a +75 offset. You really want the 25 spacer, it will hit the inner wheel well with a 315 tire. I ran widened wheels back in 2012 and ran into this issue.
Best bet which you probably won’t like is to cut your rear quarters. I rolled mine but having it cut now for clearance.
Any info let me know
Discussion Starter · #8 · (Edited)
Thanks for all the responses. I talked to Weldcraft and they are backed up 6-8 weeks. Looks like I will just go with a 275/40/17 for the new rears and move my 255/40/17 rears to the front for a nice staggered setup. I can always go the wheel widening in the future if I decide to go single.
Now I have to figure out R888R vs NT-01R vs NT-05R. :cautious:
Edit - Just ordered the R888R as they were the cheapest....
I will likely also have to now send my current rears out for polishing as they look like shit next to the new 9.5's
Administrator
sounds good, I run the r888rs in front...a little noisey but not bad.
Discussion Starter · #10 ·
Got the new 275/40/17 R888Rs mounted. I was worried about the lip touching the tire on a hard shift. I put about 450 pounds on the back of the car and the lips were about 1/4-inch from the wheels.
Went out and did a rip and had traction in all gears, only a chirp from first to second. No evidence on the tire or lips of any contact so it looks like I dodged a bullet with the 15mm rear spacer and the Tanabe GF210 spring.
Because the traction is so much better the car feels slow now. I will likely need to start looking at more power modifications. Been waiting months on the HKS Silent Hi-Power to make it here.
Still have to shave the caliper tab off to mount the 255/40/17s on the front.
Interesting enough, I received these wheels with about 15 other items and assumed they were OEM Toyota. Funny thing is there is no Toyota stamp on the face, but all of the manufacturing stamps on the back side of the spokes are nearly identical to my OEM wheels and I can't see any difference in the structure or manufacturing of the wheel in comparison to a known OEM wheel. So either these are really good copies, Toyota didn't put the "Toyota" on a certain year?, or they were shaved off?
  • Like
Reactions: Wreckless
Discussion Starter · #12 ·
Woo, I just shaved the caliper and put the 255/40/17s on the front. Car feels way better with wider tires all around. I will probably send the fronts out to get polished and repaired and put 255 r888s on the front as well. The dish on the rears looks more agressive on the front and it moves the wheel closer to the caliper.
R888s definitely hold the road. I would recommend them to anyone.
Discussion Starter · #13 · (Edited)
Just an update, THM stated my exhaust way delayed another 2 months so I have requested a refund. So its a no-go for the HKS Silent Hi-power.
I wanted to keep my car quiet, but I don't really like the look of the Drager. I also don't like the carbon look of the Carbon Ti.
It seems like the general consensus from the reviewing the last decade worth of exhaust posts is that the HKS 4" Ti seems to be overwhelmingly recommended.
I see it goes for about $1150 at PHR with an adapter.
So my question is, will I regret getting this exhaust on my BPU car?
Old School
HKS Ti is beautifully made, very loud, and some possible ground clearance issues being 4".
1 - 14 of 14 Posts
