·Help with fuel controller
First of all I have the HKS AFR.
after reading both the HKS AFR and the Apexi AFC manual, I think they perform the same fuctions. I can increase throttle response % and fuel curve at selected 11 RPM points, -50%+50% 1 pt increment.
So is there a recommended RPM points that I should dial in more fuel to accomodate 18psi?
I wanna dial in more fuel after 4000RPM to provide the engine with more fuel to see if it will lower my EGT a bit, I think my engine is running lean so I am in the process of finding out why.
thanx
Jonas
thanx
Jonas
