1 - 4 of 4 Posts
the two hardlines that run side by side in front of radiator support, down passenger side of engine and across the front cross member. what are they?
edit- nevermind. i think they are from the receiver to the pressure switches.
Supra Fan
Power steering lines
right i understand now. im no pro at pwr steering so some input would be appreciated.
i cant just bypass the hardline and run straight from reservoir- i.e remove those lines in front of radiator support?
that loop the fluid takes from the hose thru hardline to reservoir is to cool it? how important is this?
edit- i could see the need on a 4x4 with big tires, or if i was road racing, but isnt this just to prevent premature pump failure?
1 - 4 of 4 Posts
