1 - 1 of 1 Posts
Hi i had a question for the wiring of my triple pumps.
Witch cable is for the intank fuel level sensor ground?, so i can ground the sensor to the hanger with the pumps.
I will then use that cable to power feed the third pump.
The reason i want to do it like this is so i can get all cables true the stock connector.
Will offcorse solder in a thicker wire.
Just wanted to double check, there are two cables going to the intank sensor one is more to the black color, so the most logic would be that this is the ground, just wanted to double check.
Sorry for my english
Regards Anders
1 - 1 of 1 Posts
