I could use some help with wiring. I have a JZX100 I have converted to rear sump and dropped in my 87 turbo. I was given a custom Plug and Play harness from ECU masters that is not quite on sale yet (I'm testing it for them, should be released soon to the public), I have purchased an ECU masters classic as well. Does anyone know if I will have to do any special wiring to make this work? I know if I was using the stock ECU I would run power to coils, injectors, etc. but do I have to do the same thing here, or can I just simply plug the harness in, load my base map, and start it? Any advice will help. Thanks.
