I paid about $45 for the generic housings, i may need to upgrade these to get better light dispersement. The H.I.D.'s were about $450..IdRockaSupra said:Nice stuff SAS, how much did you end up paying for everything ?
You can get a H6054 sealed beam to H4 bulb conversion kit for $60-80. Just stay away from that "diamond cut" style without all the little lines on the lens (the fluting) - they're there for a reason, not just to make the lens ugly. Those little lines and angles direct the beams to where you want them to go; ie: in front of you, and cut off horizontally with an upwards flare to the right. Also be careful of the wattage of the H4 bulbs that you buy - the "xenon" style bulbs are bright but if you get cheap ones they'll burn out quick and possible melt your wires. Look for Silvania "cool blue" or "platinum white".IdRockaSupra said:Thanks ghost, but is their anyway I can get this done ( making the lights look good and light the road well ) with some regular bulbs ? 600 Dollars just for some lights is pretty crazy IMO, thanks for the info, take care.
SAS90T: those look sweet. We used to use OSRAM exclusively when I worked as a projectionist at a theatre - they lasted longer and gave us the more flicker-free light than any other manufacturer we tried. OSRAM is to Silvania as Lexus is to Toyota - kinda the snooty big brother.
Steve
