1 - 8 of 8 Posts
Eye Kandy For Enthusiasts
Searched but couldnt find anything.
I just bought two horns from Curt, one is a high pitch and the other is the low pitch horn. My question is, where do both of these horns bolt on to. I know one goes in the front by the radiator-------but im not sure which one goes where. Is this the location for the high pitch.
Also where does the other horn go, and how many horns are there on a supra. I have a total of three now.
Car never had a horn when i bought it so thats why im asking.
Hardtopper Once Again!
There is a horn where your intake would be, I am not sure which one it is. I noticed it when I did my single turbo converson, I always thought it was a horn for the alarm but maybe someone can clarify.
OK our car has three horns,one for the alarm by the intake on the struct tower,one by the hood latch that's the high and the other is a PITA to get to that's the low,it's mounted to the lower radiator support on the right side to the right of the air temp sensor,if you have a front mount it should be mounted right by the in pipe.The only way of getting to it is from under the car or removing the front bumper.
thanks man i will check it out today.
can someone tell me which one goes where as far as the "pitch" is concerned. I dont know whether the high pitch or low pitch mounts in front of the radiator. Can someone check and post.
jam98tt said:
As i said above the high goes on the top and the low down by the radiator.
My bad man, i guess i skipped over that, thanks for all your help, much appreciated
1 - 8 of 8 Posts
