1 - 15 of 15 Posts
its just as easy to put a piece of $3 - straight pipe in than it is to put the expensive hks pipe in (as long as you have an after market blow off valve). And the money you save could be used for something else.
when does this pipe actually make a difference, it seems like it is not necesary until you try to run like 15 psi
also, what kind of improvements does it make?
No One Ever Listens To Me
as you are almost correct in the fact that it wont help you noticeably until you start upping the boost....the pipe is a much better design then the stock 3k pipe.... the stocker is a bottleneck design and the hks is the same diameter for the whole thing.
hwoever i agree in the fact that its not worth paying more then 40 bucks or so for it...just to have the HKS on it. :rolleyes:
Can't touch this!
I don't see anything wrong with paying for this pipe. I feel the pipe adds to the overall look of the engine bay when it recieves a ceramic coating or a good polish!
I know $70-80 sounds like a lot but I think it's worth it!
Later
Jason
Bipolar
The "ooooh ahhhh" element of the HKS pipe is worth the money alone. Also, the HKS pipe isn't straight, it has the same contour as the OEM beer bottle pipe, and has cast in provisions for the ISC and PCV pipes.
hell with the money you save by using a straight pipe you could get a pcv catch can and then you wouldnt need the hole in the back and it wouldnt take much to secure the isc tube. also the catch can keeps the oil film out of everything. but hey if you have the money to waste go ahead pay for the name. i sure wouldnt, but thats me.
1 - 15 of 15 Posts
