1 - 4 of 4 Posts
Buy Wholesale
Since the search is disabled, i had no other choice but to post here
are the components of the boost controller that are in the engine bay itself waterproof or not???
IE would water from rain, car washing or engine bay washing be able to damage the unit???
Last year i did the spring mod and i was able to boost to 18 PSI no problem
now, the most i can boost is about 15.5 PSI or 110 KPA according to the boost controller
my thoughts are either a clutch that is starting to slip, turbos on their way out (no death whine yet tho), a boost leak somewhere, or the aforementioned boost controller issue
what do you guys think??
i was thinking of replacing the stock turbo system w/ a small single system over the winter and go from there
I really doubt it's the turbos themselves. Replace any worn hoses and experiment to see if your boost controller works at all.
1 - 4 of 4 Posts
