Silver bullet
or anyone,
I installed the hks ez lastnight and basically followed the dsbc instructions.
I hooked up port 2 to the turbo outlet (discharge) then I hooked up port 3 to the top of the wastegate actuator.Then I capped off the bottom of the actuator, capped the two at the vsv, then lastly capped the steel line that connects to the left vsv outlet.
For port 1, I just tapped into the line that I have going to my boost gauge. I noticed that silver said to tap to the stock bov line.
Did I do the install correctly, I'm not too sure how much boost I'm making, because I have the spare tire on, so when I get the drag radials on today, I will be able to get on it and find out.
Just looking to see if I installed this correctly. I did some searches and found info on boost controllers hooking to the pressure tank, etc...
thanks for any help
