Hello guys
recently I installed my bpu stuff...exhaust, dp, bcc, boost gauge and a hks evc ez. I checked everything on the evc ez and it looks fine. Its connected right, all the hoses are hooked up...the headunit piece has power. When i turn it on and put the boost to say the middle, where the arrow is on the top i hit 14psi, if i turn it all the way to its highest setting I still hit 14psi, if the boost controller is off I hit 14. No matter what i do i only hit 14psi and I am not hitting boost cut. In the engine bay, the box you install in there, it has a little plastic piece with like a rubber piece covering it. Do i want to get rid of the rubber piece? I think its some type of breather...Anyone experience this? Once i get this fixed I will be installing a egt gauge, safc, turbo timer, fmic, cam gears and intake...
Thanks a bunch =)
Dave
Thanks a bunch =)
Dave
