1 - 4 of 4 Posts
I installed a HKS EVC 5 today on my bone stock mkiv auto tt tonight and am having some issues. Before the install i would hit about 9psi. but now It hits to 9, than drops to 6 when the 2nd turbo kicks and steadys out at about 4 at wot. No matter what setting i change it to(all the way high,all the way low) I still get the same outcome. I set it up via http://supraforums.com/forum/showthread.php?t=184231&highlight=evc+install directions. any help would be greatly appreciated. this is driving me :eek4dance . a is300 w/ intake and exhaust pulled on me today :rolleyes: so sad
u buy a 10" carb spring at a local parts store and them bend 2 hooks at the end so the total length is 8" then hook one end on the wastegate actuator arm and then the other end on the spare hole in the waterpump, and your set.
this makes ur older worn out waste gate stiffer kinda like new again.
i'd get u the original post but i couldnt find it, if u cant figure it out try searching
Andrew
1 - 4 of 4 Posts
