1 - 10 of 10 Posts
Super Moderator
750-850ish depending on engine mods. Which exhaust housings do you have?
If you're just looking for a pretty dyno sheet, the awesome 1.2x correction factors at our altitude tend to make that happen lol.
Thats the power level I am looking to make so that is good to hear. Thanks for the info
I assume the exhaust housings are those supplied in the kit because I wasn't told otherwise when I purchased the car
Current Build looks like this:
272 cams
Heavy Duty ARP bolts
Eagle Rods
HKS DLI
PHR Intake
HKS 2835 twins
HKS cam gears
HKS fuel rail
Greddy FMIC
AEM EMS v1
Engmaineer
Just hadn't found one that was making more than 600wheel
I just needed to find out what numbers were possible.
What kind of power does your 3.4 make on pump?
There is a few out there making high 7's low 8's that seems where most of them end up power wise. If you want to make more you can always swap out turbos and go bigger to make more power. There is a few options for those manifolds / downpipes.
Addicted to boost
1.5BAR (22psi) with 91 octane yielded 614 hp, 538 TQ
and
1.8 Bar (26psi) with 91 octane yielded 679hp, 589TQ
Keep in mind that I have 264 cams as well. I could've squeezed a little more with bigger cams I'm sure.
What kind of power does your <3.0> make on pump?
Like I mentioned, I dont have any new dyno numbers, but from my ET's my 3.0 should be around 650-675 HP thru an auto.
On pump gas, I ran [email protected], probably around 500 HP.
Al
1 - 10 of 10 Posts
