You should see an open ended clip with 2 holes on the open ends. This clip is called a snap ring and holds the BOV to the flange.
You need to get a set of snap ring pliers to remove the snap ring. The ends of the snap ring pliers fit into the two small holes. You squeeze the pliers to allow removal and the BOV will seperate.
