1 - 12 of 12 Posts
supraman
HKS T51r kai Vs SP67GT-HO?
Which turbo would perform better in the 1/4 mile? Considering both cars have been modified equally and are manual transmission.....:)
Unless the t51R has some kinda nos to help spool the turbo. The 67 Car is gonna win.
vnt ;)
info reprinted from moreboost.org
T51R KAI 800 PS output ~= 789 bhp ~= 671 rwhp
compressor housing (GT45): 100mm inlet, 80mm outlet
turbine housing: V-Band inlet, V-Band 115.5 mm outlet - 1.00 A/R
T51R SPL 1000 PS output ~= 986 bhp ~= 838 rwhp
compressor housing: 100mm inlet, 80mm outlet
dyno 874 rwhp (uncorrected) by Bryce D. 1.0 A/R (120 shot, 264 cams, HKS GT fmic, p&p head, Crower billet rods, JE Al pistons) - site
862 rwhp by Bob H. 1.0 A/R @ 30psi (same car as B.D.)
PTE67 (CTC67, CTC67H, GA67, SP67) Moreboostaholic idea by Andi and Steve, wheel sourced and turbo built by PTE
dyno 521 rwhp by Jon S. .68 A/R, P trim (GA67) @ 17 psi (RPS, A'PEXi) - site
521 rwhp by Vivek G. .68 A/R, P trim (CTC67) @ 18psi (93 oct., Boost Logic manifold, 3row) - site
533 rwhp by Silvino O. .68 A/R, GTQ trim (CTC67H) @ 18psi (114 oct. RPS big torque manifold, 3row, 3.5" dp, 264/264, HKS Ti 4" catback, Supraformence headwork, 1mm oversize Ferrea valves, Fidenza, AEM)
544 rwhp by Andi B. .68 A/R, GTQ trim (CTC67H) @ 18.5psi (cast, 3-row, mild exhaust port) - site
591 rwhp by Andi B. .68 A/R, GTQ trim (CTC67H) @ 21.3psi (cast, 3-row, mild exhaust port) - site
631 rwhp by Andi B. .68 A/R, GTQ trim (CTC67H) @ 24.1psi (cast, 3-row, mild exhaust port) - site
596 rwhp by Jim S. .7 A/R, P trim (SP67) @ 24.5 psi (HKS, HKS Type S, G-force ecu)
635 rwhp by Jon S. .68 A/R, P trim (GA67) @ 25.5 psi (RPS, A'PEXi) - site
646 rwhp by Vivek G. .68 A/R, P trim (CTC67) @ 28psi (101 oct., K. Wang manifold, 3row) - site
678 rwhp by Andi B. .68 A/R, GTQ trim (CTC67H) @ 28.4psi (cast, 3-row, mild exhaust port) - site
712 rwhp by Vivek G. .81 A/R, P trim (CTC67) @ 29psi (101 oct., K. Wang manifold, 3row) - site
759 rwhp by Silvino O. .68 A/R, GTQ trim (CTC67H) @ 30psi (114 oct. RPS big torque manifold, 3row, 3.5" dp, 264/264, HKS Ti 4" catback, Supraformence headwork, 1mm oversize Ferrea valves, Fidenza, AEM)
682 rwhp by Andi B. .68 A/R, GTQ trim (CTC67H) @ 32psi (cast, 3-row, mild exhaust port) - site
The HKS T51KAI is closest in comparison to an SP70GT. They both use a 70mm compressor wheel.
Ranger thanks for the info. Saves me from looking up the specs. Seems like you considered both turbo's. I'm not sure where you got the 671whp rating but I do know a friend of mine has dynoed well into the 700 range without the aid of N20.
No doubt that a SP67GT-HO would perform:)
He stated above his post that he got the information from www.moreboost.org . :)
correct im looking for a new turbo also im stuck between 4 units
Vendor
hks seems to underrate their turbos by a decent amount. if a 70mm turbo can only flow just over 650rwhp thats not very good, and they rate the monster 76mm SPL at 850 wheel.
IMO if youre willing to sacrafice some spool of the 67 to go with the potential power of that 70, i would suggest you look into the 71 gtq's with the .81 a/r. they spool extremely well for the size they are and im rather confident they will out power the *relatively* outdated hks KAI.
1 - 12 of 12 Posts
