1 - 20 of 36 Posts
i've been using this element air filter for a while on my old 7mgte, no problems with it.... but everytime i read about the racing trf element.... they say for race only.... b/c the element is good for maximum airflow but the does not clean the air coming in as good as the regular hks element..... i got my 1jz in now and i dont want to risk having to rebuild it b/c some stupid dirt got in my engine.... in my opinion the trf element was very clean on the inside of the element filter.... im going to buy a new one.... it seems to me that it cleaned the air coming in pretty well... who else is using this filter????
HKS TRF ELEMENT FILTER $35
HKS regular filter $15
have you guys even seen a trf filter? how can u even judge a filter you've never seen..... im my opinion the trf came out cleaner than the regular filter i used to use.... everytime i use the old filter it gets dirty really fast... i will post pics of the filter that i used in the 7m for at least 3 years
Can you post pics of what the TRF looks like? and would it fit the HKS adapter? cause I had the hks adapter, but changed it out with a K&N filter... aightpeace
re-born
So what do you think happened to all that dirt if it didnt stop at the filter?
i doubt little dirt particles will do anything, theyll just get burned up nicely and chucked out the exhaust, unless youre rally racing or drive in industrial areas, i wouldnt worry about it.
Ang
1JZ BLING!
HKS Element - The HKS Super Mega flow element is a 2-layer, dual density, wet-type polyurethane filter that uses an impregnated viscid fluid to attract and stop damaging dirt particles from entering your engine
TRF Element - They are engineered with a single polyurethane foam layer with larger pores than standard Super Filter elements to allow greater airflow efficiency.
Basically, the regular elment has 2 layers, normal plus a more dense inner material.
TRF has just a thick version of the outer layer filter with wider holes and no dense inner material.
I've used HKS for years.. no problems... They do not fall apart unless you wash them or use them beyond their life span.
Discussion Starter · #11 ·
Slimfast supra is almost right.... the trf element is does have the same inner as the regular element.... the trf has a very different outer layer.... the outer layer doesnt look like pores that are thicker.... the outer layer is like a fuzzy stuffed animal... try to post pics sorry...
VIVA LA M.A.S.H. Midwest
Moderator, l337 M0d3r4t0r
Dirt harms the enigne by getting in to the oil supply by sticking to the cyl walls and by passing the rings, also causes dammage to the rings if it fuses to the cyl wall. Depending on what is sucked up it could be big enough to harm the turbo even something very small getting sucked up at 140000RPM will caus lots of dammage.. Take for example why many people have chipped fins on the turbo...
Chipped fins are a direct results of having something that shouldn't have been sucked up though the intake.
I'd say away form mega dirt flow.. Buy a K&N and just keep oiling it.
Found this at one of the ITG suppliers. This looks cool.
ITG does have some nice 3in outlet filters, would be fun to try with the ole AFM adaptor.
"In early 2002, Coast Fabrication Inc. entered an agreement with Induction Technology Group (ITG) to act as the exclusive North American Importer for ITG racing air filters. We import and specify ITG filters for one simple reason: THEY ARE THE BEST AIR FILTERS MADE."
Factory special order of the cone type units does seem like a hassle compared to the common K&N units. Might be worth it though. Hmmmm.
how much are they??
Any filter should keep rocks and stuff big enough to take out teh impellor. I dont know about any dust particles surviving 1400+ comb. temps... but ill take your word for it...
Ang
Republican
The thought of a little bit of dust hitting the turbine blades at 120,000 RPM is sickining.....k&n BABY!
Go All Electric
Not many people think about this due to the popularity of the product/brand name. BUT ... K&N filters are not nearly the best out there to offer ... they are among the worst. Some filter is better than no filter though.
ack you guys are making me worried, But theres tons of pplin motorsports that run open turbos with just a screen, or even wide open (esp in drag racing) and a few ppl on here? is it really that dangerous?
PS ive had a chipped fin turbo , dont know what caused it tho? maybe my filter is crappy?
1 - 20 of 36 Posts
