1 - 20 of 32 Posts
Car is being held ransom.
I am very interested in finding out what kind of octane I can make on various amounts of Toluene or Xylene. I did some calculations, which should be pretty straight forward. I am very excited to try this when spring rolls around.
Here is what I calculated:
Toluene - 114 Octane
Xylene - 117 Octane
Here's the math:
(A x Gas Octane) + (B x 114 or 117) / (A + B) = Octane Value
A = Gallons/Litres of Gas
B = Gallons/Litres of Toluene/Xylene
114 = Octane Value of Toluene
117 = Octane Value of Xylene
MEASUREMENTS IN GALLONS
1/4 Tank = 4.6GAL
5% Toluene/Xylene = 0.23GAL + (4.37GAL of Gas)
10% Toluene/Xylene = 0.5GAL + (4.1GAL of Gas)
20% Toluene/Xylene = 0.9GAL + (3.7GAL of Gas)
30% Toluene/Xylene = 1.4GAL + (3.2GAL of Gas)
40% Toluene/Xylene = 1.8GAL + (2.8GAL of Gas)
50% Toluene/Xylene = 2.3GAL + (2.3GAL of Gas)
1/2 Tank = 9.3GAL
5% Toluene/Xylene = 0.47GAL + (8.83GAL of Gas)
10% Toluene/Xylene = 0.9GAL + (8.4GAL of Gas)
20% Toluene/Xylene = 1.9GAL + (7.4GAL of Gas)
30% Toluene/Xylene = 2.8GAL + (6.5GAL of Gas)
40% Toluene/Xylene = 3.7GAL + (5.6GAL of Gas)
50% Toluene/Xylene = 4.7GAL + (4.65GAL of Gas)
3/4 Tank = 13.8GAL
5% Toluene/Xylene = 0.69GAL + (13.11GAL of Gas)
10% Toluene/Xylene = 1.38GAL + (12.42GAL of Gas)
20% Toluene/Xylene = 2.76GAL + (11.04GAL of Gas)
30% Toluene/Xylene = 4.1GAL + (9.7GAL of Gas)
40% Toluene/Xylene = 5.52GAL + (8.28GAL of Gas)
50% Toluene/Xylene = 6.9GAL + (6.9GAL of Gas)
Full Tank = 18.5GAL
5% Toluene/Xylene = 0.9GAL + (17.6GAL of Gas)
10% Toluene/Xylene = 1.9GAL + (16.6GAL of Gas)
20% Toluene/Xylene = 3.7GAL + (14.8GAL of Gas)
30% Toluene/Xylene = 5.6GAL + (12.9GAL of Gas)
40% Toluene/Xylene = 7.4GAL + (11.1GAL of Gas)
50% Toluene/Xylene = 9.25GAL + (9.25GAL of Gas)
MEASUREMENTS IN LITRES
1/4 Tank = 17.5L
5% Toluene/Xylene = 0.88L + (16.62L of Gas)
10% Toluene/Xylene = 1.75L + (15.75L of Gas)
20% Toluene/Xylene = 3.5L + (14L of Gas)
30% Toluene/Xylene = 5.25L + (12.25L of Gas)
40% Toluene/Xylene = 7L + (10.5L of Gas)
50% Toluene/Xylene = 8.75L + (8.75L of Gas)
1/2 Tank = 35L
5% Toluene/Xylene = 1.75L + (33.25L of Gas)
10% Toluene/Xylene = 2.5L + (32.5L of Gas)
20% Toluene/Xylene = 7L + (28L of Gas)
30% Toluene/Xylene = 10.5L + (24.5L of Gas)
40% Toluene/Xylene = 14L + (21L of Gas)
50% Toluene/Xylene = 17.5L + (17.5L of Gas)
3/4 Tank = 52.5L
5% Toluene/Xylene = 2.63L + (49.87L of Gas)
10% Toluene/Xylene = 5.25L + (47.25L of Gas)
20% Toluene/Xylene = 10.5L + (42L of Gas)
30% Toluene/Xylene = 15.8L + (36.7L of Gas)
40% Toluene/Xylene = 21L + (31.5L of Gas)
50% Toluene/Xylene = 26.3L + (26.2L of Gas)
Full Tank = 70L
5% Toluene/Xylene = 3.5L + (66.5L of Gas)
10% Toluene/Xylene = 7L + (63L of Gas)
20% Toluene/Xylene = 14L + (56L of Gas)
30% Toluene/Xylene = 21L + (49L of Gas)
40% Toluene/Xylene = 28L + (42L of Gas)
50% Toluene/Xylene = 35L + (35L of Gas)
ACTUAL INCREASE USING 91 PUMP GAS
Toluene
5% Toluene = 92.15 Octane
10% Toluene = 93.3 Octane
20% Toluene = 95.6 Octane
30% Toluene = 97.9 Octane
40% Toluene = 100.2 Octane
50% Toluene = 102.5 Octane
Xylene
5% Xylene = 92.30 Octane
10% Xylene = 93.6 Octane
20% Xylene = 96.2 Octane
30% Xylene = 98.8 Octane
40% Xylene = 101.4 Octane
50% Xylene = 104 Octane
ACTUAL INCREASE USING 92 PUMP GAS
Toluene
5% Toluene = 93.1 Octane
10% Toluene = 94.2 Octane
20% Toluene = 96.4 Octane
30% Toluene = 98.6 Octane
40% Toluene = 100.8 Octane
50% Toluene = 103 Octane
Xylene
5% Xylene = 93.25 Octane
10% Xylene = 94.5 Octane
20% Xylene = 97 Octane
30% Xylene = 99.5 Octane
40% Xylene = 102 Octane
50% Xylene = 104.5 Octane
ACTUAL INCREASE USING 93 PUMP GAS
Toluene
5% Toluene = 94.05 Octane
10% Toluene = 95.1 Octane
20% Toluene = 97.2 Octane
30% Toluene = 99.3 Octane
40% Toluene = 101.4 Octane
50% Toluene = 103.5 Octane
Xylene
5% Xylene = 94.2 Octane
10% Xylene = 95.4 Octane
20% Xylene = 97.8 Octane
30% Xylene = 100.2 Octane
40% Xylene = 102.6 Octane
50% Xylene = 105 Octane
ACTUAL INCREASE USING 94 PUMP GAS
Toluene
5% Toluene = 95 Octane
10% Toluene = 96 Octane
20% Toluene = 98 Octane
30% Toluene = 100 Octane
40% Toluene = 102 Octane
50% Toluene = 104 Octane
Xylene
5% Xylene = 95.15 Octane
10% Xylene = 96.3 Octane
20% Xylene = 98.6 Octane
30% Xylene = 100.9 Octane
40% Xylene = 103.2 Octane
50% Xylene = 105.5 Octane
* Note that if using Xylene, a lubricant for the gas tank is recommended. It is not neccessary to do this for Toluene.
* The Use of more than 50% of either additive is not recommended. Use more at your own risk.
* Recommended climate for Use of these products is 70*F/21*C. Any lower and you will start to have problems with cold starts.
239RWHP @ 9PSI
:stupid:
It's only the beginning..
AGlobalThreat said:
Thank you :), this should be stickied
:bigthumb:
another thing not noted.... octain ratings are shown with the (R+N)/2 method.... the reason u cant use more than 50% of a tank of either paint thinner is because the R and N figures are so far apart from one another. fuels like this have very high flash points... which means on a cold engine... you'll probly have trouble getting it to start... ive run mixtures as high as 75% toluene
Discussion Starter · #11 ·
tekdeus said:
Is it true that Toluene offers more power because it has a higher concentration of hydrocarbons than gasoline does?
Yessir. It is a carbon adder.
Kracin said:
where do you pick up xylene and toluene in bulk? and for gods sake how do u pronouce toluene lol
Any paint supply or chemical store. Its a paint thinner basically.
Well you can use more than 50%. You will have trouble with sold start, but if the climate is above 70*F, you should be ok. F1 cars in the 70's used 90% Toluene and 10% filler(race gas). You wont be able to run pure Toluene properly if thats what some of you are thinking lol :D.
when this baby hits 88mph
HamsMKIII said:
Just for curiousity, what is the average price for a gallon of each?
toluene around here is usually right around $6/g
prices have gone up and prepare for the DEA to show up asking questions if you buy much at a time.
Discussion Starter · #16 ·
Thats only if you buy 1gallon at a time. If you buy a 50gal drum its like $3 or so.
if your search there is a HUGE thread about this from i think 04 or something...but i dont think it had all those calculations.
ive read in that other thread people say you should use ATF and deisel fuel in it when you mix it.
I Love Lamp...
Thats for the xylene, i dont think that needs to be done with toluene.
mavel mystery oil... and yeah i'd still add a quart or so of that forevery tank of toluene....
u can run damn near as much as either as u want aslong as its hot. as for the xylene.. that stuffs like 1.5 times more expencive than toluene. i used to get mine at sherwin williams. they kinda look at u funny when u tell them u need that much of it and they ask what company u work for and u tell them your putting it in your car
1 - 20 of 32 Posts
